Disable door alarm
(Topic created: 10-24-2024 05:18 AM)
Dan360
Kitchen and Family Hub
Hello,
I have a Samsung fridge model RT18M62155R, the control panel does not have an on/off button for the door alarm, I would like to know how to disable the door alarm?
realaud
Honored Contributor
There should be instructions for it in your manual. If your fridge has a panel, it would be some combination of panel instructions. Why would you want the door alarm off? Do you know how many times my door didn't properly close and I didn't know it until the alarm went off?
Dan360
Thank you for replying i tried reading the manual it was too long and couldn't find anything, I wake up at 530am for work and that peeping sound while I'm getting ingredients to make breakfast drives me and my wife insane
realaud
Honored Contributor
Usually, the alarm doesnt sound until the door is open for 5-10 minutes. It doesn't usually sound if you are "just looking". My fridge has an actal panel controll to turn the alarm off. You could try Googling if your panel doesn't have the control.
Dan360
Mine seems extremely short I would say about a minute and a half of it being opened
realaud
Honored Contributor
That does seem short. Should be 5 or more minutes. I did revise my response while you were replying.
