- Mute
01-01-2025 07:21 AM (Last edited 01-01-2025 07:29 AM ) in
Kitchen and Family HubHello and happy new year!
Yesterday I upgraded the software on my Samsung Fridge (RF27T5501SR) to Family Hub 9 (Tizen 7.0) . I did this by doing a factory reset of the unit.
After the reset was complete I noticed that the View Inside app no longer worked. A default picture appeared and the error “Image recognition failure. Please try again in a moment” message appeared.
I am in IT so I immediately began troubleshooting. I suspected that the upgrade broke something. Maybe a missing driver for the cameras or something since the View Inside app had been working flawlessly for the past 2 1/2 years.
I found on YouTube how to enter into Engineer Mode and ran the Camera Test.
As suspected, the Cameras failed to Initialize.
So here I am, unable to use one of the main reasons I purchased this product. Hopefully someone from Samsung can pass this upstream to the Software Engineering teams. I am sure I am not the only owner that has this issue given the amount of complaints I’m seeing about Family Hub 9.0.
I’m looking for a bug fix release to restore this functionality. Being in the business for a long as I have, I’m under no illusion that the fix will be out anytime soon but It would be nice to get it sometime in the next 6 months.
My family really enjoys this Fridge. I hate to lose such an important feature. If anyone has any recommendations I’m all ears, Of course I’ve done all of the normal troubleshooting tactics, “red button” turn off, soft reset, factory reset, etc.
Best regards,
Chris
- Mute
01-01-2025 08:33 AM (Last edited 01-01-2025 08:34 AM ) in
Kitchen and Family HubSince you've already done a software (Family Hub 9.0) reset, as well as a factory reset, I'm not sure what to tell you.
My only thought is to ask you to pull out the fridge and unplug it from the wall for 5 minutes, then plug it back in.
Sorry, I can't think of anything more.
- Mute
01-01-2025 06:46 PM (Last edited 01-02-2025 05:51 AM ) in
Kitchen and Family HubThanks for the suggestion Dan I will give that a try. May I ask what model do you have? I’m working with a RF27T5501SR manufactured January 2022.
- Mute
01-01-2025 06:59 PM in
Kitchen and Family Hub- Mark as New
- Mute
01-02-2025 05:50 AM in
Kitchen and Family HubThanks Dan for sharing your model. I did unplugged the unit for 5 minutes and fired it back up as suggested. No joy.
- Mute
01-02-2025 01:38 PM in
Kitchen and Family HubSame issue after latest firmware. Cameras broken same error msg. Tried factory reset, unplug, press red button. Nothing works
- Mute
01-04-2025 11:54 AM in
Kitchen and Family HubHi, Thx for sharing. Which model do you have?
- Mute
01-10-2025 05:16 PM (Last edited 01-10-2025 05:29 PM ) in
Kitchen and Family Hubsame issue here- really hope there is some fix or work around.. maybe a patch that can be done manually seems there is a USB port by the red power switch.
I did get the camera to initialize a couple times and failed to initialize once.. and it captured the inside image- however going back out - same black screens for each camera.
I also get the ERROR code 41 to call service center.
- Mute
a month ago in
- Mute
4 weeks ago in
Kitchen and Family HubI am on with Samsung repair now with this exact issue and the only thing they say is it is out of warranty. The software update broke this 24 hours ago, but now it is on me to pay for a service call? I have purchased thousands of dollars worth of Samsung electronics. The company WILL lose me as a customer if they do not fix what they broke.
