Family Hub RS27T5561SR/AA not dropping ice
(Topic created: 06-22-2024 05:20 PM)
MTpockets
Kitchen and Family Hub
Hello,
tray fills up but ice won’t drop. When I use the test button all appears to work as it should. Not showing any error code and completed power cycle. Not sure what to do next. Anyone have any suggestions with this issue? Thanks in advance!
Samsung_Moderator
Hello! Thank you for reaching out! I would recommend trying the information in the following link: https://www.samsung.com/us/support/troubleshooting/TSG01209062/#ice-does-not-dispense.
If this does not help then this will require service. Depending on your warranty you will have a couple of options.
- If your unit was recently purchased, you can check with your retailer on their return/exchange processes.
- If you have an extended warranty you can reach out to them to have service set up.
- If you're within the one year warranty, you can Private message me or one of our moderators or you can call in directly at 1-800- 726-7864 with your full model and serial number to have service setup
- If you're OUT of warranty, you can use this link below to find a service center in your area.
https://www.samsung.com/us/support/service/locations/
ChaosSaber
Honored Contributor
Contact a technician to look at it
Samsung_Moderator
