- Mute
10 hours ago in
Kitchen and Family HubHi,
I am looking to purchase the only countertop microwave available in Samsung store: MS19DG8500SRAA / MS19DG8500SRAA. https://www.samsung.com/us/home-appliances/microwaves/countertop/1-9-cu-ft-countertop-microwave-with...
In the description, it links to an optional microwave trim kit: MA-TK8020TS/AA
However, in the microwave trim kit description, it lists it is compatible with ' MS19M8000AS/AA' which is NOT the model listed above. I am assuming that the product description for the trim kit is outdated?
Will this fit? Also all I see are 1 star reviews which is not really confidence inspiring... Anyone have any experience?
Thanks in advance!
- Mute
8 hours ago (Last edited 8 hours ago ) in
Kitchen and Family Hub- Mark as New
- Mute
Kitchen and Family HubThe Trim kit is for countertop microwaves that are inserted into a built in shelf/cubby. Its a square piece of plastic with slide in 90.
- Mute
7 hours ago in
Kitchen and Family Hub@dennis11364 The important thing here is the dimensions of the microwave.
The model listed as compatible with the kit is the same dimensions (23 5/8" W x 13 9/32" H x 18 7/16" D) as the microwave that you are purchasing. Therefore, the kit will work.
