Range (NY63T8751SS/AA) thinks temp probe is plugged in; oven won't work
(Topic created: 10-11-2023 07:23 AM)
absinthe1021
Kitchen and Family Hub
I do have an open service ticket number for this: <HIDDEN>
I have a Samsung NY63T8751SS/AA (gas range, electric oven), purchased in mid 2021. The following problem recently REoccurred (second occurrence).
In the midst of cooking on Bake in the oven, the oven alarms with a double beep and displays the following message:
Nothing can be done to clear this message. After a short while, the oven shuts off. If you turn it back on, you just get the error message again. I even went to the trouble of shutting off the breaker (at the advice of Samsung customer service, who I called) and turning it back on, but the error persisted. Unfortunately I had a meatloaf in the oven that was about 10-15 degrees shy of being fully cooked.
This happened once before, within the unit's warranty period. I apparently called Samsung at the time, who sent out a technician to "fix" this.
The "temp probe" in question was supplied with the oven and is intended to be plugged in to a circular receptacle in the upper part of the oven. I have never used it. But apparently, when this problem occurs, the oven thinks one is plugged in. Yes, I did try to fix the issue by plugging in the temp probe and then removing it, but that didn't clear the error code.
Now Samsung tells me that the unit is out of warranty and so a charge will apply to come and "repair" the oven. This thing was $2400 and is only a bit more than 2 years old. I absolutely do not want to pay to have this "fixed." The issue seems to me to be a design flaw and not a matter of wear and tear or something "breaking." I have this intuition that perhaps some grease or other buildup on the temp probe receptacle/slot inside the oven is causing this problem. In searching online, it seems like other users have dealt with the issue by repeatedly plugging and unplugging the temp probe, or in other cases by in some way cleaning the receptacle (though some of these cases I've read about were not this stove, not even a Samsung stove, or not even the identical issue that I'm having but only related to the temp probe).
Trouble is, I can't try any method of repairing this myself because the problem has now gone away (I had to finish the meatloaf using the Bake function in my microwave ... also a Samsung, haha). But of course now I'm worried that the next time I'm cooking something, and the oven heats up, the problem will recur. This would be a disaster if it happened, say, on Thanksgiving.
If this is going to be a recurring issue, Samsung should give me some advice on how to mitigate the problem: Either "clean" it myself, or some way to avoid it. The problem is unbelievably frustrating in an appliance that cost over two grand. I can't imagine having to pay a technician every year or two to fix this. Honestly, before I would pay several hundred bucks to have it "repaired," I'd just buy a $750 flat-top range and sacrifice my gas stove, just for the sake of reliability and simplicity.
quehouse
I used a Q tip and rubbing alcohol to clean inside the probe connection. Make sure to push the Q tip as far as you can and do it 2 or 3 times. Now I do this every time after doing an oven self clean.
Members_NYtWLqU
CHEAP, EASY SOLUTION --- Consolidating a couple of suggestions from other people and adding detail:
Problem is caused by steam. Happened to me when dehydrating.
1. Stick a Q-tip with a little rubbing alcohol deep into the probe port (upper right, just inside the oven). Swish it all around to clean out any water residue and gunk.
2. Let it dry out.
3. Screw a size M10 acorn nut onto the probe port. (Buy at hardware store or Amazon)
4. Done
