Reset NSI6DG9500MTAA Bake mode default temperature
(Topic created: 08-18-2024 05:03 PM)
OldLadyWho2
Cosmic Ray
Kitchen and Family Hub
Does anyone know how to reset it on a NSI6DG* induction oven? It was 350 when I got it. I did the 400 degree initial bake for 1 hour as directed and that is the default now. I probably pressed something to cause that reset, but I have no idea. Tech who was here to check clock had no idea other than to create a favorite. That is more steps to go through than I want. I am hesitant to do a factory reset, but that is only way I see. Anyone know what 'restart range' is? Sounds like turn it back on if you accidentally turned it off to me, but I am assuming nothing!
Samsung_Moderator
Hello! Thank you for reaching out! From looking at the user manual, there is no way that I can see how to change the default temperature. Each cooking mode that you use will have its own default temperature. You can look at this more using the link to the user manual below.
https://downloadcenter.samsung.com/content/UM/202408/20240802133847251/01._IB_FULL_NE9100D_NSI6DB950...
1 Reply
Samsung_Moderator
