- Mute
ā02-25-2025 04:23 PM in
Kitchen and Family HubMy ice maker stopped working. I've reset it nothing. I've unplugged it nothing I've unplugged it and turned off circuit nothing. I've taken filter out and unplugged it nothing. I've used blow dryer nothing. I have no idea what it could be. oh checked lines too all good. I did notice there was a piece of plastic covering door switch that has been on there since we got it that said remove. once I removed it the switched popped out. do you think it being pressed in all the time it now is bad.
- Mute
ā02-25-2025 04:32 PM in
Kitchen and Family HubI would suggest contacting support and having a tech diagnose the issue.
https://www.samsung.com/us/support/contact/
If you've found my post to be helpful, Please like my Comments āāā.
If my response resolved your issue, please press the Like and āāā to Accept as Solution button.
- Mute
ā03-02-2025 12:08 PM in
Kitchen and Family HubMy ice maker itās not working too. Itās not making any ice, itās dry and doesnāt have any ice stock in between parts. I have try all the posible troubleshooting recommended by the manual and by people here and online searching. Did you find a solution for yours?
