Any way to disable Accessibility Menu Shortcut (mute button 3 sec)
(Topic created: 03-05-2025 10:21 AM)
WillieJoe
Cosmic Ray
LED and OLED TVs
Is there any way to permanently disable the Accessibility Menu Shortcut Key (hold mute for 3 seconds)????
My 80 year old mom keeps doing this (holding mute for 3 sec) and enabling the darn Voice Guide - making the TV unusable . I have to drive over her house to disable the darn thing once a month!!!!
Please tell me how I can permanently disable this !!!
Thank you!!
WillieJoe
Cosmic Ray
LED and OLED TVs
Aww thank you for follow up.
Unfortunately - the "accessibility menu" does not have a "accessibility shortcut" option to turn off.
Maybe newer TVs have that option!!
If not, might be worth recommending to engineering - have seen many others get extremely frustrated with this accessibility menu.
Thank you so much!!
Willie
Samsung_Moderator
LED and OLED TVs
Hello! Thank you for reaching out! Some TVs do not have the option to disable the shortcuts. So that I may look into this further, can I have your full model number?
WillieJoe
Cosmic Ray
LED and OLED TVs
Sure - that would be awesome!! Thank you!!
UN65TU7000FXZA
Samsung_Moderator
LED and OLED TVs
I believe you may be able to disable the Accessibility Menu Shortcut. The Manual states you can turn on or turn off the accessibility functions such as Voice Guide, Picture Off, Video Description, Caption,High Contrast, Enlarge, Learn TV Remote, Learn Menu Screen, Multi-output Audio, Slow Button Repeat, Accessibility Settings, and you can move to the Learn TV Remote and Learn Menu Screen pages.
If you are using a Smart Remote, follow the directions below.
-On the Samsung Smart Remote, there are 2 thin horizontal rocker buttons next to each other located slightly below the middle of the remote. The one on the left is the volume button. Press and hold the volume button to open the Accessibility Shortcuts menu. Even if the Voice Guide is set to Off or muted, when you press and hold the volume button, the voice guide for Accessibility Shortcuts is enabled.
If you are using a standard remote, follow these directions.
- Press the CC/VD button or press and hold the MUTE button to open the Accessibility Shortcuts menu.Even if the Voice Guide is set to Off or muted, the voice guide for Accessibility Shortcuts is enabled.
Let us know if this helps.
WillieJoe
Cosmic Ray
LED and OLED TVs
I really appreciate you looking into this !!
Unfortunately, the above solution does not solve my problem.
My desire is to make as if holding MUTE button for 3 seconds does NOTHING (meaning does NOT open up the assessibilitu menu).
If pressing mute for 3 sec gets you to that assessibility - my mom will find a way to turn on that darn Voice menu LOL.
And I will be taking many urgent rides to her house to fix.
Simplest fix is to tell mom not to press mute for 3 seconds - but unfortunately, as we get older, that is not working 😞
Thank you for looking into, and if know how to disable the mute button for 3 seconds from entering the accessibility menu - I would be ecstatic 🙂
Samsung_Moderator
LED and OLED TVs
Hello! Just want to try one more thing to see if this works please try the following:
  • Press the Home button on your Samsung remote.
  • Go to Settings (gear icon).
  • Scroll down and select General.
  • Choose Accessibility.
  • Select Accessibility Shortcut.
  • Turn it off
Please let me know if this helps!
WillieJoe
Cosmic Ray
LED and OLED TVs
Thank you so much!!
Willie
Samsung_Moderator
LED and OLED TVs
You are very welcome! Thank you for trying! And will reach out to them. Have a good day!
