bbqbrad
- Mute
ā11-02-2024 09:17 PM in
LED and OLED TVs
I got on here and asked well samsung website to ask if I could use the auto rotating wall mount with my new 65in s95 oled 2023 tv and i was told yes should work just fine well pretty sure they were wrong cause I can not get it to work . This reall sucks cause could of just got a cheaper one and would of worked just fine is there anyway I can get it to work .
Samsung_Moderat or
- Mute
ā11-06-2024 06:58 AM in
LED and OLED TVsHi there, I'm so sorry to hear you're having trouble with this. Could you confirm specifically which wall mount you are using? Also, any additional details about the issues you're having trying to get the TV mounted would be helpful.
bbqbrad
- Mute
3 weeks ago in
LED and OLED TVs
It the auto rotating wall mount for 55-65 in tvs mine is 65 in and it mounted to wall just fine even got it to show up on Bluetooth list but either I don't know what to do to make it rotate or it just doesn't work with this tv
bbqbrad
- Mute
ā11-07-2024 11:45 AM in
LED and OLED TVs
The 55-65 auto rotating wall mount from samsung. I got it mounted just fine but can not get it to rotate at all
bbqbrad
- Mute
ā11-07-2024 11:47 AM in
LED and OLED TVs
Even got it to show rotating accessory in my Bluetooth drop down but can't figure out way to get it to rotate
