Backlight replacement
(Topic created: 07-14-2024 09:20 AM)
GoldieRose84
LED and OLED TVs
My tv is not showing the picture. When a flashlight is put on the screen i can see the picture. So im guessing its the backlights any tips or tricks you may have for me to get these replaced?
ChaosSaber
Honored Contributor
LED and OLED TVs
I'd check out a few local shops, since you can see the screen with a flashlight, just tell em its the backlight, but sometimes its cheaper to just replace the TV
ChaosSaber
Honored Contributor
LED and OLED TVs
meself
Honored Contributor
LED and OLED TVs
Either take in to replace the screen I e backlight oleds or get a New tv
