Disable WiFi on HG48ND690 Hospitality TV
(Topic created: 03-07-2024 12:46 PM)
kwat
LED and OLED TVs
I have an HG48ND690DF hospitality set in standalone mode. I only use it with a Roku stick which provides its on wifi. I don't have a wired jack close to the set (but could if required) and the set keeps trying to access my wifi using its internal wifi adapter. Is there any way I can stop this?
Samsung_Moderator
LED and OLED TVs
Hello! Thank you for reaching out! Unfortunately, this is not possible to disable Wi-Fi on the TV.
1 Reply
Samsung_Moderator
LED and OLED TVs
