EXCESSIVE DATA USAGE ON NEW TV
(Topic created: 01-02-2025 11:28 AM)
KHIELS
LED and OLED TVs
NEW TV MODEL QN65Q72DDFXZA, HAD FOR TWO MONTHS .
THIS TV USES ALL OF MY WIFI DATA, IT USES 2/3 MORE DATA  THEN
MY OLDER TV. WATCHING THE SAME PROGRAMS ?
ANY SUGGESTIONS ON HOW TO FIX ISSUE? I HAVE READ IT MAY BE
DUE TO HD OR ULTRA HD SETTING?
ANY SUGGESTIONS?
realaud
Honored Contributor
LED and OLED TVs
Why would you use a smart TV on a metered/limited wifi plan? Do they even still have those, or are you confusing wifi with mobile data and using your phone as a hotspot? Reduce the quality of your streams.
LED and OLED TVs
TVs and streaming services assume you have unlimited internet, otherwise they should be used with minimal video quality settings over the network.
meself
Honored Contributor
LED and OLED TVs
Could be from updates to apps or streaming
realaud
Honored Contributor
LED and OLED TVs
