I have an 75" QN75Q900RBFXZA 8K tv and need a new One Connect box
(Topic created: 01-09-2025 04:07 PM)
userMRgX24CU5v
LED and OLED TVs
the TV volume raises on it's own, I can't select menu items, as they advance on their own, and the HDMI switching wont work. I've narrowed it down to a bad One connect box,  BN91-21195E.
I've been told that they no longer make this part. I replaced this box once already, under warranty. I couldn't just buy a replacement. Samsung was insisting that I pay them to come out and diagnose it (which I don't need) and then charge for a replacement. So, in other words, I would get charged $300 for the housecall, and another $600 for the box.
So, Now I have a $4300.00 TV that was the top of the line, and is now  useless. Any help, Anyone???
JBTechfanatic
Black Hole
LED and OLED TVs
When you purchased your TV, it should have come with two sizes of the one connect cable. I would recommend trying the other cable to see if that helps. Otherwise, this is the parts website. Remember, if it says out of stock, sometimes it will list an alternate device that will work https://samsungpartsusa.com/
Robin621k
Honored Contributor
LED and OLED TVs
You can look on Ebay for the One connect box. Make sure to read the feedback of the sellers before purchasing!
userMRgX24CU5v
LED and OLED TVs
I've been looking on Ebay for that particular box for 6 months. It is model specific.
Robin621k
Honored Contributor
LED and OLED TVs
Yeah, I just looked, nada.
JBTechfanatic
Black Hole
LED and OLED TVs
