Make it possible to adjust brightness and color settings on phone while watching
(Topic created: 04-16-2025 01:08 PM)
user2EcCyCqhXT
LED and OLED TVs
Suggestion
Samsung_Moderator
LED and OLED TVs
Hello! Thank you for reaching out! You can do this, but it is using the remote app from SmartThings on the phone. You can go into the settings the same way you can with your remote. As for changing the settings directly from the phone, this is not possible. Please use the link below to help set this up.
https://www.samsung.com/us/support/answer/ANS00083002/
Sonboy415
LED and OLED TVs
You can lol
meself
Honored Contributor
LED and OLED TVs
Think that's been a option on most phones for many years
Samsung_Moderator
LED and OLED TVs
