My Samsung 55” UHD is unable to connect to server
(Topic created: 01-26-2020 08:30 AM)
user2XH7YAYMMC
LED and OLED TVs
Hi,
I bought my Samsung 55" UHD Smart tv - Samsung 7 series (55) in December 2019 and all was working fine with the apps.
I got cable this weekend And now when I go to the apps it says "unable to connect to server. Try again later." The TV is connected to the internet just fine. And my internet isn't down. I can go to Already installed apps like Netflix and it works fine streaming.
When I try to look for an app I get an Error "The server is under maintenance. Please try again later. (1544104)
It won't let me sign into Samsung from my tv either. I get an error "Unable to connect to the Samsung Server. Please try again later. (116)
can you please help me fix this?
thank you,
rob
MsBri1
Neutron Star
LED and OLED TVs
Hello, have you tried changing the channel on the router? Especially in apartment situations, you can have a few routers on the same channel and this can create connection and speed issues.
If your TV won't connect to the internet, you should perform a network status test to help you choose which guide you need. Navigate to Settings > General > Network > Network Status and run the test. Pay close attention to any error messages, and whether there is an X between the TV and the router or between the router and the globe.
Important:
  • If the network drops after the TV was off overnight, and you have an RU7 series UHD TV (RU7100 - RU7300 and RU710D - RU730D), try cold booting the TV (hold the power button down on your remote until the TV turns off and then back on). Then you will be able to reconnect to the internet. A software update will be available to fix this issue soon.
  • If at any point you need assistance with configuring settings on your router, contact your ISP if they provided the router, or the manufacturer of the router if it was bought separately.
Check the network status test for an error message.
Power cycle your network equipment.
Reset the TV.
  • Navigate to Settings > Support > Self Diagnosis > Reset and enter your PIN (the default is 0000). After the reset, try connecting again.
Make sure your Wi-Fi network is compatible with the TV
  • Network requirements vary between TVs and are listed in the user manual. As an example, 2018 models NU6***, NU71**, NU72**, and NU73** only support 2.4Ghz networks. They will not even see a 5Ghz network.
  • If the network is not compatible with the TV, the TV will be unable to see or connect to it.
  • In most cases, the default settings for home networks are fine. However, if the network settings have been adjusted, confirm that they meet the requirements of the TV.
Disconnect some of your other things that are connected to Wi-Fi:
  • The more things you have connected to your Wi-Fi network, the weaker the signal will be. If you have 2 tablets, 3 phones, a refrigerator, and an Xbox, the signal could be very weak. Disconnect all other Wi-Fi devices from the network and then try to connect the TV.
  • If this does the trick when none of the previous steps worked, it means you have more devices connected than your router can handle and you should upgrade your router or connect fewer devices.
Try connecting to a different network.
  • This is a troubleshooting step to help determine what the issue might be. For instance, if a mobile device with hotspot functionality is available, have it create a network and try to connect the TV to the hotspot. If any other networks are available, they can be tried as well.
  • Note: If the TV can connect to any other network, service is not required, and the issue is with the network that you're unable to connect to. Contact your ISP if they provided the router, or the manufacturer of the router if it was bought separately.
If the issue continues, we recommend contacting your ISP or the manufacturer of your router for further assistance.  If they help you determine the TV as the source of the issue, service may be required. You are welcome to send us a private message with the full model code and serial number in order to see if the unit is within the warranty or if it qualifies for any possible options. Messages can be sent using the following link or by visiting any mod's profile. --> http://bit.ly/33ipYnO
SamsungCaleb
LED and OLED TVs
Have you tried power cycling the TV? And have you tried power cycling your router?
Tricky_
LED and OLED TVs
I am having the same problem, although my TV is a different model.
It shows that my TV is connected to the internet, and I am able to stream content on the Netflix app, so I'm not sure what cycling the router is going to accomplish.
When you ask Power cycle the TV, you mean to turn it off, or to unplug it?  Will that reset ALL my settings and apps?
RH
Tricky_
LED and OLED TVs
I also followed the self diagnostics to connect to the Smart Hub, and it tests out that everything is fine.
Please advise on further things to get this working again.
Not applicable
LED and OLED TVs
We are sorry to hear about this. Please send the model and serial numbers, along with the current software version, to this PM Link.
userLSCyWG3ZbJ
LED and OLED TVs
I have been experiencing the same issue for nearly a month. Netflix wont work and also other apps like prime, hbo go and etc. Tried resetting smart hub and samsung tv but still the same problem with the server. Also cant even log out or remove my samsung account. Tried logging in also with another samsung account but it still says unable to connect to samsung server. Thank you so much.
Model code UA82RU800GXXP
Software version T-MSMUABC-1372.2,BT-S
swwsjc
LED and OLED TVs
Model UN55RU7100FXZA
Software version T-MSLAKUC-1335.0
Please advise, thanks.
Tricky_
LED and OLED TVs
What fixed it for was power cycle (unplug, count to ten and plug into power outlet) the TV and rebooting my router.
doesn't make a lick of sense to me but it worked.
userbbsezUOVuB
LED and OLED TVs
I had this same issue and unplugging everything for a bit worked for me. Thanks!
SamsungJam
LED and OLED TVs
We're glad that you're up and running!
