Old LN19C350 TV not showing HDMI source
(Topic created: 11-11-2022 11:48 AM)
RandomUsername
Cosmic Ray
LED and OLED TVs
I wanted to get rid of that annoying black bar that periodically shows up every once in a while because it was really distracting, So I looked online and read that changing the source settings would help so I did and now options like the HDMI source are greyed out and when I went into "self diagnostics" there is no reset option (the only sources I can acess are PC and TV
imageWhen I go into the source list
imageWhen I try to select it
(Also I kinda lost the remote for the TV and have only been able to use those buttons on the bottom of the TV to navigate around)
JUMP TO SOLUTION
RandomUsername
Cosmic Ray
LED and OLED TVs
I have a HDMI cable connected that's about it other then the power cord obviously
RandomUsername
Cosmic Ray
LED and OLED TVs
Alright I'm at the plug in paly option now what do I do?
jayblaze84
Cosmic Ray
LED and OLED TVs
Did you reset it
jayblaze84
Cosmic Ray
LED and OLED TVs
Did you reset the tv
RandomUsername
Cosmic Ray
LED and OLED TVs
Ok so when I go onto plug and play and select home the three options are
Air
Cable
Auto - both
RandomUsername
Cosmic Ray
LED and OLED TVs
Yes
jayblaze84
Cosmic Ray
LED and OLED TVs
Auto both
RandomUsername
Cosmic Ray
LED and OLED TVs
Ok now it shows up this what do I set them to? 20221225_171922_12362_1672006763.jpg
jayblaze84
Cosmic Ray
LED and OLED TVs
If you have cable or anything connected you can just leave it at the 1st one that stands for standard
jayblaze84
Cosmic Ray
LED and OLED TVs
If you don't have anything connected you can just skip it
