usersPa1OW4848
- Mute
04-15-2025 05:18 AM in
LED and OLED TVs
I have a 2018 series 6 43-in flat screen! It is model number n u6900 ish! And I have approximately 9% storage memory left! I have deleted all of the channels and uninstalled all of the applications that I can possibly stand to do without because truly what is a TV without apps!? Even when I do uninstall every single one of them I'm still only left with about 18% to 20% memory storage! Can anyone please please please help me get this down to a manageable level!? I have no idea how to do this!
Solved! Go to Solution.
Robin621k
Honored Contributor
- Mute
04-15-2025 08:48 AM (Last edited 04-15-2025 08:49 AM ) in
LED and OLED TVs
Your TV is 7 years old, and apps will probably not be supported much longer. If it isn't in your budget to buy a new one, the best way to get it to work smoothly is to buy a streaming device. This will give you more storage, apps that will keep being updated. I like Google TV, their new device is kind of pricey at $99. An alternative is the Google TV 4K pro made by ONN a Walmart brand with a built-in speaker that gives you hands-free voice commands. I have this one. It is snappy, has 32gb of storage and the remote is amazing.
Robin621k
Honored Contributor
- Mute
LED and OLED TVs
usersPa1OW4848
- Mute
04-15-2025 08:42 PM in
LED and OLED TVs
Thanks, my friend! That makes perfect sense! Have a great day!
Robin621k
Honored Contributor
- Mute
04-15-2025 08:45 PM in
LED and OLED TVs
You are welcome
