Factory-Reset-has-frozen-TV-at-step-3
(Topic created: 04-13-2025 12:28 PM)
cbsimpson1
LED and OLED TVs
I have this same problem. The Moderator's response to the original post was not helpful.
He suggested going to Settings to resolve it. But like the original questioner, my remote won't go to Settings. And like him, I tried Samsung Support. And I got the same result. "What a shame. Guess you need to buy a new TV."
That seems like an expensive answer to a question that seems to only require a software or firmware fix.
Daniz
Galaxy
LED and OLED TVs
Im sorry to heard that
Daniz
Galaxy
LED and OLED TVs
cbsimpson1
LED and OLED TVs
Thanks. But my problem is that my TV doesn't seem to have a manual power button and the remote is completely frozen so I can't get to Settings. My TV is a UN70NU607F.
Any other thoughts or suggestions?
Daniz
Galaxy
LED and OLED TVs
Something like this picture under tv
cbsimpson1
LED and OLED TVs
Ha! Found it. Unfortunately, it only has about four settings, volume up, volume down, source and off.  None of those work. And holding it down to do a hard restart didn't do anything either. Just cam back to the stuck on 3 setting.
Daniz
Galaxy
LED and OLED TVs
Did you unplug the tv ? If not try to unplug and wait couple of minutes and re plug again this will reset all hardware and sofware. If none of these works contact the support
cbsimpson1
LED and OLED TVs
I will try again. But I did the unplug and wait a couple of minutes solution before. No luck.
I will try holding the manual reset button for a longer time.
I'll be back to you. And thanks very much for taking the time to try to help me with this.
Daniz
Galaxy
LED and OLED TVs
Sure im more than happy if i can help
cbsimpson1
LED and OLED TVs
No luck. I guess I'll just have to buy a new TV. And it won't be a Samsung!!!!
Daniz
Galaxy
LED and OLED TVs
