Remote working except volume
(Topic created: 03-08-2025 01:03 PM)
Meghanh1188
LED and OLED TVs
My remote is working totally fine except for volume button (up/down/mute). I reset my TV and the volume button worked fine after that…only to stop working again about a week later. I have no external speakers connected to TV.
I have Samsung au8000 TV
Samsung_Moderator
LED and OLED TVs
I see. Since all the other buttons are functioning, and resetting the remote didn't help, we would recommend replacing the remote as the next step. You can find replacements through our parts department either online at SamsungParts.com or by calling 1-800-627-4368.
SamsungBrown
LED and OLED TVs
Hi, Meghanh1188. Welcome to the Community! I know how frustrating not being able to adjust the volume on your TV can be.
Have you tried resetting your remote? To do this, remove the batteries and hold down any button for 15 seconds, then re-insert the batteries. Hope this helps!
Meghanh1188
LED and OLED TVs
yes i have reset the remote with no luck.  every other button on remote funtions properly
Samsung_Moderator
LED and OLED TVs
