Changing firmware with USB?
(Topic created: 03-13-2025 07:24 AM)
Thibautbfz
LED and OLED TVs
Hello,
I bought 2 HG40EC890XB tvs, they are hotel models. I would like to know if it is possible to install a different firmware via USB in order to have a “normal” tv interface for home use.
Thanks in advance for your help!
Samsung_Moderator
LED and OLED TVs
Thanks for reaching out. Support for US products is the focus of this forum. As your device is a non-US model information is severely limited. We kindly suggest that you use this link to look for a support team in the area your product was manufactured in: https://www.samsung.com/visitcountry/
Did you know? Your region more than likely has a community of it's very own!! Check out the following link and join the community in your region: https://r2.community.samsung.com/
1 Reply
Samsung_Moderator
LED and OLED TVs
