Series 4 m4500 wobbly legs
(Topic created: 12-25-2024 07:16 AM)
Lglenn
LED and OLED TVs
Just opened a new Samsung 4 m4500 and the legs are wobbly making the tv lean forward. How do you tighten the legs properly.
Samsung_Moderator
LED and OLED TVs
Hi there, Thanks so much for asking about this. I can definitely understand the importance of having secure legs on your TV. I found this link that should be helpful. It has detailed information on what to do if the TV stand or legs are loose.
https://www.samsung.com/us/support/troubleshooting/TSG01002133/
Please let us know if this helps.
meself
Honored Contributor
LED and OLED TVs
Screw driver I think Philip tighten them
Samsung_Moderator
LED and OLED TVs
Gab0607
LED and OLED TVs
I have the same problem. Legs on the m4500 TV being loose causing the TV to have a very slight lean forward.
