Sleep Timer Shortcut
(Topic created: 3 weeks ago)
userAx7CoH0Gix
LED and OLED TVs
I saw a couple of older threads on this topic, but they're closed to replies.  I agree that pressing several buttons to get to the sleep timer option is ridiculous.  Here's my workaround:
Grab an older Samsung remote with a physical Sleep button.  It works with both my Q60 and Q90 TVs.  The only drawback is that it returns to the Home screen, so you need to press OK/Select to get back to your programming.  However, you can memorize that sleep button signal with a smart remote/hub (I tested it with SwitchBot), add the extra OK, and activate that routine with an app or Alexa.  This approach is harder than it should be, but better than the built-in options.
1 Reply
Samsung_Moderator
LED and OLED TVs
What a great suggestion! Thanks so much for sharing this useful workaround!
