Spectrum cable box won’t connect
(Topic created: 3 weeks ago)
Dennisbirr
LED and OLED TVs
My Spectrum cable box stopped connecting to my  Samsung tv, UN75NU8000.  The same cable box connects to other cable tvs.
user_ams007
Planetary Samsung Care Ambassador
LED and OLED TVs
Try Unplugging your TV and cable box for a few minutes, then check the cables from the Cable box to the TV, plug in both devices and then turn on your TV and make sure you select the correct Sorce HDMI 1 or 2 ,If don't see a picture, select the home screen menu on your TV and then select the broadcasting menu and select service provider information and settings and follow the instructions to add your cable box, if this doesn't work select the device care menu and run the diagnostic tools to check your TV for any issues
Dennisbirr
LED and OLED TVs
I have done all those things and still won’t connect to cable box. Broadcasting menu doesn’t show Spectrum as something to connect
user_ams007
LED and OLED TVs
Try selecting my service provider isn't listed this will bring up an option to select Spectrum. Make sure you are using HDMI 1
https://www.samsung.com/us/support/answer/ANS00078931/
Dennisbirr
LED and OLED TVs
I am not finding where I can select my service provider
Dennisbirr
LED and OLED TVs
The Broadcasting link says it’s not available
Dennisbirr
LED and OLED TVs
 Still can’t get the Samsung to recognize the cable box
uservWMaNn1ptQ
Cosmic Ray
LED and OLED TVs
So you said cable box, so I'm assuming it connects via HDMI. Correct .. and you correcting have the HDMI cord in the proper port on the TV and even on the back of the cable box ..? Some cable boxes have a HDMI in and out .. make sure it's on the HDMI out on the box
Dennisbirr
LED and OLED TVs
I checked the HDMI cables and they are in the correct spots. I had the HDMI cable in this port and it works, but then one week it didn’t work. Something happened in between because it worked and then it didn’t
