TV reset and stuck on step 3 of setup
(Topic created: 11-17-2024 08:40 PM)
dgzr282
LED and OLED TVs
Did a factory reset because the tv menu was not responding.  TV is now stuck on Step 3 and unable to clear/ go back, or reset again.  Prior post says there is a solution but its just a setup video.  Cannot get into menu to do a reset.  Turning tv off and unplugging if for multiple minutes and turning it back on just brings up step 3 again.
JUMP TO SOLUTION
userUKU7nEfShj
LED and OLED TVs
I just went thru this and it WORKS!  Great idea, thanks.
Members_ySx36KS
LED and OLED TVs
You should try and access the factory maintenance menus where there is another factory reset.  This worked for me after my QLED TV was hung at Step 3.  Assuming you can still turn the power off to put the TV into standby mode (I could) and have access to a Samsung remote with number buttons, you should try the the approach described here.
https://www.reddit.com/r/techsupport/comments/1eaq8xk/comment/lenqh0n/?utm_source=share&utm_medium=w...
It worked for me.
user2goXMCMpzW
LED and OLED TVs
Exactly this happened to me & this easy sequence fixed it.RDT_20241212_2228036463271532146201159_1000017597_1734071283.jpg
marknjennyf
LED and OLED TVs
This is the only thing that worked for me.  Now I just have to fix the backlight problem
user0WopqqX3s4
LED and OLED TVs
Thus worked for me. Thanks!
Did your steps then just skipped everything during setup and manully configured after.
