Missing the spectrum app on the TV
(Topic created: 2 weeks ago)
RhinaGuerrero
LED and OLED TVs
Hi mine QN90F dosent support spectrum app it's dosent vome pre install and I tried installed but it dosent find it and mine QN90D does .
Samsung_Moderator
LED and OLED TVs
Hello @RhinaGuerrero! Thank you for reaching out! If the app isn't available on the app store for the TV, then that means that the TV doesn't support the app. I would recommend reaching out to Charter Spectrum about the availability on the TV.
1 Reply
Samsung_Moderator
LED and OLED TVs
