janczak96
- Mute
07-23-2025
04:00 PM
(Last edited
2 weeks ago
by
SamsungMatt
) in
Solved! Go to Solution.
Pianodude58
Supernova
- Mute
07-23-2025 04:06 PM in
LED and OLED TVs
The Xfinity XR11 remote does not have a dedicated "Home" button like some other remotes. To access the main menu on an X1 system, you need to press the Xfinity button. This button will typically display the main menu at the bottom of the screen. You can then navigate through the menu using the arrow keys.
1 Reply
Pianodude58
Supernova
- Mute
LED and OLED TVs
