- Mute
06-09-2023 03:39 AM (Last edited 11-24-2023 01:54 PM by SamsungRei ) in
LaundryI have WF42H5000AW/A2 model washer from many years. Although i used it so often because of tough work routine. But every time i used it it worked perfectly but now from some time i noticed i completely goes out of power after some time when started. I checked the wall outlet to confirm power availability, also tested ground and other things but did'nt found a fault.
what more should i do for its troubleshooting.
Solved! Go to Solution.
- Mute
10:14 AM
(Last edited
06-09-2023
10:17 AM
by
SamsungStephani
Hello @Salena jack
Welcome to our Samsung Community. I want to thank you for reaching out the Community and let you know it will be my pleasure to assist with this matter as requested.
To get started, I've located this resourceful article for those additional troubleshooting steps and have attached them here- https://www.samsung.com/us/support/troubleshooting/TSG01203022/#washing-machine-will-not-turn-on-or-.... I recommend completing all steps as advised and wish you luck with getting this resolved.
And, I'd like to add, if you have any further questions or feel the need for a more one-on- one approach for direct assistance please contact us directly using any method listed below to proceed with that aspect:
Facebook- https://www.facebook.com/samsungsupport/
Twitter- https://twitter.com/SamsungSupport/
Instagram- https://www.instagram.com/samsungsupport/
or
Private Message by selecting any moderator and clicking on the chat option *with your full model and serial number, * and I would love to assist you further.
- Mute
10:14 AM
(Last edited
06-09-2023
10:17 AM
by
SamsungStephani
Hello @Salena jack
or
- Mute
06-10-2023 10:29 AM in
LaundryThanks, will do!
