userOg2SSszkSo
Burn in problem
JUMP TO SOLUTION
On my samsung monitor I have burn in problem. Is that covered under warranty?
1 SOLUTION
Honored Contributor
Re: Burn in problem
JUMP TO SOLUTION
Thanks! Based on the Warranty information, it doesn't appear as though this model is covered for Burn-ins. I would reach out to our business support team to confirm this though: 866-726-4249.
10 REPLIES 10
Honored Contributor
Re: Burn in problem
JUMP TO SOLUTION
Possibly? Can you provide the model of the monitor and a pic of the burn-in?
userOg2SSszkSo
Re: Burn in problem
JUMP TO SOLUTION
burn in effect
Looks worse in person. Monitor is Samsung C27F591
Honored Contributor
Re: Burn in problem
JUMP TO SOLUTION
userOg2SSszkSo
Re: Burn in problem
JUMP TO SOLUTION
Do they have mail? I am not a native english speaker.
That is not the only problem on the monitor, it has some green areas on sides. It looks like a backlight bleeding but it has green color. Here are the pictures of top and left side:
Top of the screen (not the best quality picture but you can see the problem)
Left side of the screen
Also it has color banding problem and blocky artifacts in black.  Here is the example of my color banding problem.
This is my Samsung monitor:
https://www.youtube.com/watch?v=3WY0yOhvvQQ
and my friend monitor, some 6+ years old cheap TN:
https://www.youtube.com/watch?v=8Nbim_rzSUM
You can see very obvious lines between transition and blocky artifacts in last picture.
What do you think of this, is this covered under warranty?
Honored Contributor
Re: Burn in problem
JUMP TO SOLUTION
I honestly couldn't say 100%, my best recommendation would be to reach out and see what they say. I don't have an exact email address for them, but there is this email form: https://www.samsung.com/us/business/email-form/?CampaignCode=products-computing-monitors-300-series-...
userOg2SSszkSo
Re: Burn in problem
JUMP TO SOLUTION
Ok, thank you very much. I will send them mailSmiley Happy
Honored Contributor
Re: Burn in problem
JUMP TO SOLUTION
You're very welcome! Let me know if I can help further! Smiley Happy
userOg2SSszkSo
Re: Burn in problem
JUMP TO SOLUTION
In those warranties information you provided (link above) is a link to monitor F390, mine is F591....
Honored Contributor
Re: Burn in problem
JUMP TO SOLUTION
This model just happened to have multiple warranty links available and I clicked the first one without reading too carefully. Upon pulling it up though, they look very similar as far as the terms go: https://www.samsung.com/us/support/service/warranty/LC27F591FDNXZA
