- Mute
11-08-2021 03:41 PM in
Monitors and MemoryGreetings! I just realized I lost the 4 screws to attach the vesa mount to the back of the monitor, I can't seem to find them anywhere, does anyone know the size of the screw? trying to find information online but I can't find any and it seems that the 4 screws that came with the stand cannot be removed. Any help will be really appreciated
Solved! Go to Solution.
- Mute
11-08-2021 04:46 PM in
Monitors and MemoryGood afternoon. The G7 monitor has a standard VESA 100 x 100 mount, so the screws will be sized M4 x L12. You can get them from any hardware store or online retailer.
- Mute
- Mute
11-08-2021 05:05 PM in
Monitors and MemoryI truly appreciate your help! Take care!
- Mute
11-08-2021 05:08 PM in
Monitors and MemoryYou are most welcome.
