Monitor C24RG5 doesn't play sound and cant adjust picture mode, brightness,etc
(Topic created: 03-10-2020 03:31 AM)
userhkFgB6962t
Monitors and Memory
I connect my monitor into my VGA which is Gigabyte GeForce GTX 1660 OC through the HDMI port and I can't play sound as well as adjust brightness, picture mode.
Please help
Picture mode and some features lockedPicture mode and some features lockedBrightness is locked too :<Brightness is locked too :<Thank u
SamsungLou
Monitors and Memory
Your available options are dependent on your input signal and other settings on the monitor. This is from page 27 of the user guide.
You can find more information in the user guide at this link.  http://downloadcenter.samsung.com/content/UM/201903/20190305111215528/MONCRGZA-00_CRG5_NA_Eng_201903...
LongHiker
Samsung Care Ambassador
Monitors and Memory
That monitor doesn't have speakers.
userhkFgB6962t
Monitors and Memory
Oh, I didn't know that. Thank you very much.
But how about the other setting that I can't adjust?
SamsungLou
Monitors and Memory
