- Mute
9 hours ago in
Monitors and MemoryHello Everyone,
I just purchased an 32" Odyssey OLED G8 UHD Gaming Monitor (Model Num: LS32DG802SEXXY) [the 2024 flat screen version] and although impressed with the Monitor I have had a number of annoying issues with it. This is my second issue.
After Powering on the monitor I can display the home page, change input, change brightness etc. Then after making even the smallest change or just exiting the OSD. I cannot display it again.
The monitor doesn't respond to the remote (except the Power Button) which shuts down the monitor.
[Given this, and that i can navigate the OSD with the remote initially, I suspect it is NOT the remote]
When the OSD is not responding to the remote, I try and display the OSD using the crappy joystick thingy on the back of the monitor. When I do, the OSD does eventually display however I cannot exit any OSD menu. It will not close. Again I have to Power off the monitor and then restart for it to become responsive.
Anyone else have issues with the OSD?
I am using firmware 1004.
