- Mute
10-28-2022 01:37 AM in
Monitors and Memoryits really downside as 3k$ monitor cannot even support multi inputs at the same time, when will Samsung release a firmware to support that ? PBP mode has seen since last 10 years, and product like this cannot support .
Solved! Go to Solution.
- Tags:
- Odyssey Ark
- Mute
11-20-2022 09:13 AM in
Monitors and MemoryAt this time the Ark does not allow for more than one input at a time. There is a work around. You can use Airplay or the windows equivalent to cast your pc to one of the inputs and your console on the other.
Hopefully Samsung will have a fix for this soon. Hoping a firmware update, but I'm not sure.
- Mute
10-29-2022 09:20 AM in
Monitors and MemoryThe new ARK in Cockpit and Multiview will display 3 screens.
Don't try to compare ARK to older PBP sytems.
- Mute
10-30-2022 07:10 PM in
Monitors and Memoryyes but 3 screens not from input, its only working with 1 input and 2 apps... so like we cannot using pc along side with playing console...
- Mute
10-31-2022 01:43 AM in
Monitors and MemoryDid you check the Specifications and Data sheet to see what interfaces it contains before you bought it?
- Mute
11-04-2022 08:10 PM in
Monitors and MemoryUseless comments.....
- Mute
