Samsung Odyssey Plus ingame menus will not center?
(Topic created: 05-15-2019 08:52 PM)
The_Nephilim
Cosmic Ray
Monitors and Memory
Hi All,
I had bought the Vr headset 2 weeks ago and was able to have it work fine no problems.. Just last night I noticed while ingame the menus are not centered and they are on the floor of the ingame room..
In Elite dagerous there is a HMD Recenter keypress well I assigned a joystick button to it and it centers for a millisecond then goes back to the floor.. I am unsure why it will not center as before I had no problems with the centering of the ingame menus..
Looking into it since yesterday and found countelss posts about recentering the headset which I have done.. I tried setting the floor which is perfect now but the ingame mneus continue to be on the floor and I can not see them well enough to navigate the game menu to play..
Even when I am in the cockpit in Elite Dangerous my head is on the ceiling and in DCS World I am above the canopy..
So what will cause this behavior?
JUMP TO SOLUTION
The_Nephilim
Cosmic Ray
Monitors and Memory
Yes now in both games the recenter was working.. so what I did incase it is not to clear on  the solution I updated Windows 10 and it had several updates and one of them must of fixed it because it now works..
So double check Windows updates as I did because the other day there where none and yesterday there was.. so maybe it was a hot fix or somethnig for wmr headsets..
The_Nephilim
Cosmic Ray
Monitors and Memory
OK this is wierd but it happened again.. I was playing DCS world earlier and there was no problem.. I cam out and was on desktop so I thought I did not have Open VR Advanced setting installed so I installed it and bam I had the problem of the menus not being centered and can not center them with the recenter hotkey..
I think this problem stems from Open VR Program.. so this is not solved yet so if a admin can remove the solved to unsolved as of yet I would appreciate it..
I am going to reinstall the WMR Portal..
The_Nephilim
Cosmic Ray
Monitors and Memory
OK it appears my hunch was probally correct.. I uninstalled Open VR Advanced setting and removed the folder then I rebooted and voila the menus where fine and I could recenter them with the hotkey so I do not think the windows update did anything initially??
So if you have that happen where the menus ingame don't recenter and you have Open VR advanced settinngs installed try uninstalling it and remove the folder and reboot annd see if the menu hotkeys work again as they did for me..
Samsung_xcb2uWZ
Monitors and Memory
Hard to use vr i have headaches that seem to swell my head....help
