Samsung Smart monitor M80D slimfit webcam. How to use or Zoom and Whatapp vieo calls?
(Topic created: 02-08-2025 04:43 PM)
Members_BiJmg1a
Monitors and Memory
Hi. I am having problems to use my samsung smart monitor m80d webcam slimfit for whatsapp and zoom meetings. It is not shown on those programs setup and it seems that only the cam works for workouts. My monitor is connected to my PC via HDMI, and on that PC i have installed Whatsapp and Zoom apps. Thank you for your answers.
ddaniel51
Red Giant
Monitors and Memory
Have you connected a USB cable from the PC to the monitor for the camera functions?
Did you read your monitor manual?
Members_BiJmg1a
Monitors and Memory
Yes, I have connected my PC to the smart monitor via HDMI and also USB C, and the monitor shows the webcam from my PC. If I search the one Slimfit Cam from the monitor it is independant and show only option for workout, not even a way to adjust or for setup. If I open Zoom and Whatsapp and go to setup on those apps, they don't recognize the Slim fit webcam. I read on Samsung that it is only via DEX that you can make videocalls, but that is nonsense, because they claim that it works with video calls. I didn't connect the USBC to the magnetic entrance, but to the monitor port, although someone claims that it worked with usb C cable.
Members_BiJmg1a
Monitors and Memory
I read the user's manual. They tell you that it is easy, but it is not. That camera experience only works for workouts, not videocalls.
