Audio help with Frame TV
(Topic created: 09-02-2025 04:17 PM)
userwejbfBWR79
QLED and The Frame TVs
Hey everyone I have a Sony str dh 590 receiver and 2 in wall yahama speakers as well as a Sonos arc sound bar. I can not for the life of me figure out how to wire it so audio plays out of each of them. Here is a picture of the inputs on the receiver.
LongHiker
Galactic Samsung Care Ambassador
Sorry but this site is for getting help with Samsung US products. None of your devices are Samsung products.
userwejbfBWR79
I’m sorry but isn’t the frame tv made by Samsung?
LongHiker
You never specified that you were using a Frame TV. I don't have one so wouldn't recognize a random component.
userwejbfBWR79
There’s clearly a one connect box right there
Robin621k
Honored Contributor
With all due respect, a quick glance doesn't make it evident it is a one connect box, unless you punch in very closely.
You should have started off with "MY FRANE TV" is having issues!
GaryB82
I was thinking it was a Xbox before I zoomed in.
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
Robin621k
Honored Contributor
All different kinds of components, Sony, Sonos Yamaha and a one connect box.
GaryB82
If you've never used a one connect box that would look like any random piece of equipment
userwejbfBWR79
It’s posted under frame tvs
