Can I control xfinity x1 cable box with RF using Samsung One remote
(Topic created: 04-20-2024 10:33 AM)
Iansul
QLED and The Frame TVs
Can I control xfinity x1 cable box with RF using Samsung One remote?
I just upgraded to the x1 box and as noted by many others, the IR control is horrible.
I’ve seen a couple of older posts, but nothing recent.
I see old posts that mention enabling IR remote (and Power On with Mobile)  in Network Expert settings. I did that but still don’t see the RF Remote option on the Comcast device on the Universal Remote Setup page.
If using RF isn’t possible I’d be willing to go with an “IR Blaster” if it’s possible with my Samsung Frame, is there a way to do that?
Samsung_Moderator
Hi there, Thanks so much for asking about this! It is possible to set up your Samsung remote as a universal remote to control your connected devices, such as a cable box or sound system. I've got the link below to more details on how to do this. Please let us know if this helps.
https://www.samsung.com/us/support/answer/ANS00089902/
1 Reply
Samsung_Moderator
