Problems with HDR and Game Mode!
(Topic created: 07-27-2024 10:53 PM)
sl3nd3rmann
QLED and The Frame TVs
Hello everybody!
I recently bought a new Samsung TV: the Neo QLED 50QN90C which I use as a monitor.
When I activate the game mode of the TV the luminosity of the TV got better but the colors seem to have got more bland-less vibrant or maybe the contrast got different.
The HDR does not seem to be on. It says HDR off in the settings that pop on the bottom.
Q: What is the issue? How can I get the HDR on?
I use a  HDMI 2.1, 8K60HZ/4K120HZ, 48Gbps, HDR cable and a RTX 4080 together with the TV.
Noobie
Nebula
1) Yes game mode changed the display settings (what a surprise 😑)
2) Settings >> Display >> Other settings (May be the wrong name) >> HDR mode
sl3nd3rmann
1) This is my third Samsung TV I used as monitor and I have other 2 Samsung Tv in the apartment.
No TV so far has lowered or increased its luminosity turning on/off game mode while brightness is being max out. So it is a surprise.
2)There is no Settings>>Display>>Other settings>>HDR mode
I have Settings>>Picture>>Expert Settings>>>>Auto HDR Remastering which is not grey out or Settings>>Connection>>Game Picture Expert>>Game HDR which is off and greyed out.
I checked with my PS5. It works with the console. The HDR is automatically on.
SO I have like this
Gaming PC:
Game Mode: On.
Gamma: BT.1886
Game HDR: Greyed out
Auto HDR Remastering: Not greyed out
Settings that pop on below:  FPS 144Hz
                                                       HDR off
PS5:
Game Mode On.
Gamma: ST.2084
Game HDR: Not greyed out
Auto HDR Remastering: Greyed out
Settings that pop on below:  FPS 60Hz
                                                       HDR on
sl3nd3rmann
Q:Anyone else?
sl3nd3rmann
Q: Anyone with has similar issue that found a solution? Is this forum dead?
ziiip
If you hold down the play/pause button in game mode, the game mode menu pops up where you can change the picture mode. Also in the non-gamer "picture -> expert settings" menu you can play around with the options (eg colour tone makes a big difference).
My QN90D is brighter in non-game mode.
Regarding HDR, you need to turn it on in your operating system.
In Windows, you right click on the desktop -> select display settings -> turn on HDR
sl3nd3rmann
For some reason things look worse with HDR settings on from windows. Looked at images, movies and games. 😞
ziiip
My screen is much dimmer in HDR, I tried it for 1 minute and then went back to SDR. 😄
