Sound output in Workspace
(Topic created: 09-09-2024 07:22 AM)
jmcdhome
QLED and The Frame TVs
I have a Samsung Q60BD 55 TV with workspace set up. I am using a Lenovo t14 Gen 4 laptop running Win 11 Ent. Workspace is installed and working just fine.
The problem is that audio is playing on both my PC and on the TV. I want to sound to be just on the TV.
I cannot select the output source from my PC. All drivers are current using Lenovo System Update. But the only output available is RealTek. Also available since installing the Workspace app is Spatial Sound for Windows Sonic for headphones. Using that makes no difference.
If I use MS remote desktop to another PC, I do not have this issue. It is easy to choose which, the target or the source, on which to play sounds.
Any idears?
1 Reply
Dantedms
I´ve the same problem... in Brazil.
