Tv Mount for a Frame Tv on Murphy Bed
(Topic created: 07-16-2024 01:38 PM)
Nm77
QLED and The Frame TVs
CAN A FRAME TV BE MOUNTED TO A MURPHY BED?
realaud
Honored Contributor
Why would you want the TV under the bed?  I don't see why it can't be as long as a) it's mounted securely, b) there is enough clearance when the bed goes down, c) there is nothing underneath the bed, d) you put the bed down gently, c) you don't have a lover, as I'm sure vibrations won't do the mounting hardware any good.
Please mark any response that helped you as your solution.
1 Reply
realaud
Honored Contributor
