alternate remote replacement model 2019 Q64R - tv QE55Q64RATXZT - remote BN59-01311B
(Topic created: 09-02-2023 01:12 AM)
labentia_signa
QLED and The Frame TVs
Good morning,
I'm going crazy as it seems that my tv model has only just one remote model, that is BN59-01311B, that i can't find on samsungparts, only at a very expensive price on Amazon or similars.
Somebody could please tell me if there's some other remote i can use for my tv? For example BN59-01312 or similar... Can't fine anything anywhere!
Samsung_Moderator
Thanks for reaching out. Support for US products is the focus of this forum. As your device is a non-US model information is severely limited. We kindly suggest that you use this link to look for a support team in the area your product was manufactured in: https://www.samsung.com/us/common/visitlocation.html
Additionally, if you scroll to the bottom of the page on the website for your region, you might discover that your nation provides its very own support forums, just like this one! Just look for the Community Option.
However, for US model TVs, typically any Samsung remote can be paired to any Samsung TV and operate it. Additionally, there are many 3rd party universal remotes that may be compatible; but you'll need to check with their manufacturer to be sure.
1 Reply
Samsung_Moderator
