Docked smart hub vs full screen smart hub on S90C
(Topic created: 03-12-2024 09:32 AM)
user3zgJPh8Rjn
QLED and The Frame
On my older Samsung TV the smart hub was docked to the bottom of the screen and did not take up the entire screen. Switching between apps and input sources was very easy. (Example: home, right right, enter).
The new "full screen" smart hub is visually confusing and difficult to navigate. It is subjectively slower as well. Is there a way to use the 'docked, partial screen' interface instead of the new full-screen smart hub? If not, how can I make this feature request?
Samsung_Moderator
QLED and The Frame
Hello! Thank you for reaching out! Unfortunately this is not possible, but I will tag this post for our engineers to see.
1 Reply
Samsung_Moderator
QLED and The Frame
