Re-level No-Gap Wall Mount
(Topic created: 01-27-2021 10:06 AM)
userc73DfWXIwd
QLED and The Frame
Hello,
I was able to remove my Samsung Frame TV from the wall mount by turning the TV gently to the right until it popped out from the mount.
Ready to reinstall the TV back into the wall mount and noticed that the bracket (into which the TV snaps into) is now slanted downwards towards the right (image attached below).
Tried to level it by rotating it to the left with my hand (before hooking the TV back) but it will not move.
Question - Once I place the TV back into the hook, will I be able to level it by rotating it to the Left? Or, do i need to level this before placeing the TV back into the hook (and how do i do this since it will not move with normal pressure)?
Any guidance will be very much appreciated!
userc73DfWXIwd
QLED and The Frame
In case anyone encounters this issue .....
Took a chance and reinstalled our Frame TV back on to the No-Gap Wall Mount. Once installed, it took minimal effort to level the TV  back into a horizontal position.
1 Reply
userc73DfWXIwd
QLED and The Frame
