- Mute
02-10-2021 05:58 PM in
QLED and The FrameSolved! Go to Solution.
- Mute
03-15-2021 05:42 AM in
QLED and The FrameI recommend letting a service technician have a look. Send your full model code and serial number via private message to get started.
- Mute
03-14-2021 10:46 PM in
QLED and The FrameHello, did you end up doing a repair? If so did it fix the problem and how did it go? Also if the repair doesn't work are you still able to return or replace the TV?
I just received a 75" frame with backlight bleeding. The local bright spots in the bottom two corners (bottom right is worst) is pretty bad and obvious when watching movies, especially if it has the black letterbox bars.
Do you have a picture of yours? I'll try to attach one of what mine looks like. Let me know how the repair went and what you ended up doing.
Thanks!
- Mute
- Mute
03-15-2021 05:43 AM in
QLED and The FrameAn Accepted Solution has been marked and provided for this thread. The thread will now be locked for further replies. in hopes to keep the integrity of the thread from steering in a non-technical manner. If you have a separate concern, feel free to post again or send one of our moderators a private message with more details. Please note duplicate posts on similar subjects starting 2/1/21, will be removed to keep our community organized and make it easier for our users to find resolutions and needed content. Remember that if you do make a post, please include as many details about your symptoms as possible. Also, make sure that your title is a good summary of the overall situation that's occurring with your product. Thank you for being part of the community!
