S10 Ultra Battery Issues
(Topic created: 10-23-2024 05:02 PM)
smrtblue
Tablets
The S10 Ultra battery really stinks I tend to use my tablet daily for around 2.5 hours for watching YouTube and those 2.5 hours will take the battery from 80% to 30%. This is with the screen brightness turned down and all current app updates and tablet updates applied. This has been the one Samsung tablet after the 7 and 9, I have regretted buying. Anyone else seeing this?
CasualMember
Comet
Tablets
My guess is that it has a battery issue
meself
Honored Contributor
Tablets
Not used a tablet but think be similar battery wise as a phone where if your using apps or gaming or browsing the battery will not last as long as say text or calls for example
smrtblue
Tablets
There is no background apps running this has been a consistent issue for 2 weeks, even running optimization.
Tablets
You might have to run diagnostics first. Then, if there is no problem, dive into your settings. Put all apps to sleep and stop them from running in the background.
ButtaBean_420
Black Hole
Tablets
I think the problem is the YouTube App I've noticed when watching videos on my S24 Ultra it has been draining the battery started happening since the last couple of updates but battery doesn't go drain that fast when watching Netflix Paramount+
