Bespoke Laundry Combo display stuck in talkback mode
(Topic created: 12-12-2024 03:08 PM)
tm491
Washers and Dryers
Brand new WD53DBA900HZ Washer/Dryer Combo. During initial setup, the Accessibility mode was turned on. This causes a voice reading of each displayed screen or button press. However, any button press ONLY results in the voice feedback without the button function being activated. This includes the Gear icon such that the Accessibility mode cannot be turned off. Been through all the troubleshooting with Support to no effect. Anybody run into this one before?
Noobie
Comet
Washers and Dryers
Double tapping the thing you want to click will help you šŸ¤—
-Noobie
Noobie
Comet
Washers and Dryers
Btw why would you even turn off accessibility settings lol
tm491
Washers and Dryers
Well, I don't need the audio feedback. And the buttons produce no other response which is a bit of a problem.
tm491
Washers and Dryers
Tried that. Alas, did not work. Just talks to me twice!
tm491
Washers and Dryers
The problem was solved by replacement of the Display board. Replacing the Display board appears to be fairly easy once the entire front panel of the appliance is removed. However, Samsung apparently replaces the entire front panel rather than just the board itself. Does not seem to be the most efficient or cost-effective approach. I wonder what the rationale is.
Now, on to discovering why Calibration mode does nothing.
