DV45K6200EW/A3 DRYER- Need help trying to fix as it's not working
(Topic created: 05-31-2024 10:49 PM)
userrHhArEayOH
Washers and Dryers
HI I got this dryer that is not working and trying to bring it back to life, Ive already found two thermistors that need to be replaced. Currently getting power but not turning on, I am currently waiting to replace these two parts, clean out the lint, and reset it, everything else seems to have good continuity, the other thing I noticed is the wiring to the heating element seems totally different then anyone else who has this model, with 2 reds 2 blacks 1 white 2 blues and a 3 line element. Can someone confirm if this is currently wired correctly because it doesnt seem right, without cutting and tracing the wires. I have a pic
userrHhArEayOH
Washers and Dryers
Motor is good, wheels, white spring thing forgot what is called, belt is good, power comes on, makes a click when it tries to start and wont spin, all buttons work, did a reset, found two bad thermistors got those about to replace when they get here. Wiring seems off but cant find what else it could be, latch is good, no child lock
userrHhArEayOH
Washers and Dryers
