userooJdGKh2tb
Dryer Model DV56H9000EP/A2 won't turn off
JUMP TO SOLUTION
The dryer, like many other Samsung dryers, will not shut off when cycle ends. I must open the door to stop drum from turning. Pressing the power off button does nothing. I've read several posts on this website, and many dryers have the same issue. Why doesn't Samsung recognize this and correct it? The dryer is two years old, this is ridiculous.
1 SOLUTION
Re: Dryer Model DV48H7400GW/A2 will not turn off
JUMP TO SOLUTION
userEIWIyBrM8p, please send us a private message with the full model code and serial number: Link
Honestly if the unit will not power off after a cycle, repairs are needed. In order to look into this further please send us a private message and we can look into coverage for you.
14 REPLIES 14
Re: Dryer Model DV56H9000EP/A2 won't turn off
JUMP TO SOLUTION
Please send us a private message with the model and serial number.
userEIWIyBrM8p
JUMP TO SOLUTION
Hello,
It seems that your dryers are very faulty and will not last for more then a few years. MY dryer DV48H7400GW/A2 will not turn off.
what is the solution to this. how can we fix it.
JUMP TO SOLUTION
Cableguy Bill
JUMP TO SOLUTION
I have the same problem now with my dryer..  DV50F9A7GVP/A2  wont shut off.  This is ridiculous. Went to work and dryer has been running all day  very dangerous...
JUMP TO SOLUTION
Hello @usernp7AyRyYUY, mind shooting us a message so we can look into this a little further?
userZuc3qiru6h
JUMP TO SOLUTION
Was is hot? Mine ran for 2.5 hours, would’ve been longer if I hadn’t come home. I opened it and it was extremely hot and it smelled burnt, my dryer is only a little over two years old and it also has been rattling from a year old!!!
userWiejB9TnbG
JUMP TO SOLUTION
Wow, there are a TON of these Samsung driers with this exact issue all over the internet, doesn’t even seem to matter what model # it is?  Mine, DV56H9000EP/A2 was purchased because it was the largest capacity washer out there, then it was recalled very quickly about the top needing bracing or some such. Now the dryer won’t heat or stop unless I open the door. Tried unplugging it, no help.  Took the control board and unplugged/plugged back in-worked ONE time and same old story.  For what I paid for these, they sure haven’t performed nearly as good as expected.  I’m told it’s the control board, but for the price they want for the part, I think I’ll just go buy a different brand?!
JUMP TO SOLUTION
We are sorry to hear about this. Please send your serial number to this link and we will look in to this.
Annah
JUMP TO SOLUTION
My dryer wont turn off! This seems very dangerous! To have ANY machine that you CANNOT TURN OFF is extremely dangerous! @SamsungJam @SamsungLou  many many users are having the SAME problem. This machine needs to be recalled or the PCB replaced for free. This is not an isolated event. It is ALL of these machines. Please respond.
