eshramko
- Mute
ā05-08-2024
02:17 PM
(Last edited
ā05-09-2024
12:49 PM
by
Samsung_Stephan
My Samsung model wa50k8600av/a2 active wash superspeed smartcare vrt fills with water, then drains then fills and drains and repeats until I stop it and put it on spin mode. I replaced the water level pressure sensor today and got it to agitate but when it moved on to the rinse cycle, it went back to the same repeating fill/drain issue. Any other possible fixes. I checked the water input and they seem fine. The drain is also apparently fine. No filter in the top load model to clean. ????
