Washer won't turn on
(Topic created: 07-27-2024 12:24 PM)
Babyboo19
Washers and Dryers
Washer won't turn on after a few cycles so we gotta unplug it for a few hours than works like nthn happen. We have new power cord. Help someone it's a top load washer
realaud
Honored Contributor
Washers and Dryers
Have you checked the outlet it's plugged into? I thought my old washer had bit the dust when it would stop mid cycle and would not drain. Bought a new washer and same thing happened, then discovered the outlet itself was to blame. Changed the outlet and everything was fine. Except for me being mad tbat I got rid of a perfectly good washer and spent money on a new one.
cpss1
Washers and Dryers
I agree with the plug solution, but when you replace the wall plug be sure to install a GFCI (ground fault circuit interrupter) because the plug is near the sink and the washer uses water. It's made to save your life and it works.
