- Mute
04-26-2022 03:12 PM in
4K, 8K and Other TVsPress home, press down = Universal Guide. Shows content from different sources. Great.
All the way at bottom is parental lock. Set programme rating lock to 12. Almost all icons change to this lock icon and require my pin including content below thay rating -
Am I completely misunderstanding how this is supposed to work? Also is there a way to have it still display the thumbnails but require a pin?
Thanks in advance 🙂
Solved! Go to Solution.
- Mute
04-28-2022 12:52 PM in
4K, 8K and Other TVsHello! I understand how this can be a cause for concern with your parental controls not working properly, and want to see if you have tried the information in the link below?
- Mute
